Hi Kindly let me know how many times the red light blinks
Condition
Code
Service Actions
Processor thermal protection activated.
Power LED blinks red twice, once a second, followed by a two second pause.
- Make sure the computer air vents are not blocked and that the cooling fan is running.
- Open the hood, press the power button, and see if the processor fan
spins. If the fan is not spinning, make sure the fan cable is plugged
into the cable header on the system board, and that the fan is properly
installed and seated.
- If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
- Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed.
Power LED blinks red three times, once a second, followed by a two second pause.
NOTE:
This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly.
Power failure (power supply is overloaded)
Power LED blinks red four times, once a second, followed by a two second pause.
- Check the
voltage selector, located on the rear of the power supply, is set to
the correct voltage (the correct setting depends on the region).
- Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
- Check if a device is causing the problem by removing all attached
devices (such as disk drives and expansion cards), then power on the
system. If the system enters POST, power off and replace one device at
a time, repeating the procedure until the system power failure
reoccurs. Replace the device that caused the failure, then replace each
of the other devices and confirm that they are functioning properly.
- If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
- Replace the system board.*
Pre-video memory error.
Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
- Reseat the DIMMs in the memory slots on the system board, then power on the system.
- Replace the DIMMs one at a time to isolate the faulty module.
- Replace 3rd-party memory with HP memory.
Pre-video graphics error.
Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded.
For systems with a graphic card:
- Reseat the graphics card and then power on the system.
- Replace the graphics card.
For systems with integrated (on-board) graphics, replace the system board.
PCA (system board) failure. ROM detected failure prior to video.
Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded.
Invalid ROM based on bad checksum
Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
- Reflash the ROM using a ROMPaq diskette.
System does not power on.
No beeps or blinks since the system is not functioning.
Press and hold the power
button for less than four seconds. Perform the following steps
depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
- Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
- Remove the expansion cards one at a time until the 3.3V auxiliary
light on the system board turns on. If removing a card turns the light
on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
- Make sure the computer is plugged into a functioning AC power outlet.
- Open the hood and make sure the power button is securely fastened
in the power harness and that the harness is connected properly to the
power connector on the system board. In other words, make sure that the
power button is making contact with the power circuit.
- Make sure the power supply cables are connected properly to the power connectors on the system board.
- Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
