Hi
I have a Lacie harddrive. The only numbers on it are N2870. I plug the USB port in. My laptop cannot see the Lacie and the light on the lacie flashes green / red.
Help
Re: Hi
I have a Lacie harddrive. The only numbers on it...
Check to see if your laptop has USB2 capability. It maybe that you are trying to hook a USB2 drive onto a usb 1 port. Also many postings over the internet indicate a lot of problems with Lacies. Try hooking up the drive to the usb port. Power down the laptop and then power it back on.
It's a safe drive, which means you need to install it and have the appropriate security to get into it. The appropriate security is a fingerprint taken when the drive was originally installed.It's a safe drive, which means you need to install it and have the appropriate security to get into it. The appropriate security is a fingerprint taken when the drive was originally installed.
You can't post conmments that contain an email address.
Impossible to tell. The Lacie N2870 is a hard drive storage device, but the hard drive in it can be whatever was put in it. You will have to open it up and see what the label on the hard drive says, or easier, go to Windows File Explorer, right click on the drive and click Properties.
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open. Inside is a 2.5 inch laptop sized harddrive. An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple. 1) Obtain a 3.5 inch IDE external enclosure 2) Remove the 3.5 IDE harddrive from the LaCie's case. 3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure. An example of a 3.5 IDE (PATA) external enclosure,
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive. The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure. (Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem? No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive. However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into. It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board. Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside. The room used is a Clean Room. A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed. Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room. They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure, (The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
The drive letter and USB port are not inherently tied together. you can give it a drive letter as long as nothing else is going to use that letter inherently, and be fine. Did giving it "F" work?
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone. Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Go down to the bottom of the page, and under the green -> Download Now <- heading, click on -> User Manual The reason I posted the link to the User Manual, is that you can use a USB to USB cable for power. You plug one end of the USB cable, into an available USB port on your computer, and the other end, into the LaCie DVD+RW external optical drive. (You need two available USB ports on your computer. One for power, and one to connect the LaCie external optical drive. This USB cable, is called an Interface cable)
The USB end, that goes into your computer, (Laptop or Desktop computer), is the USB A style end. (Male) This is what it looks like, http://en.wikipedia.org/wiki/File:USB_TypeA_Plug.JPG
The USB end, that plugs into the Lacie optical burner drive, is a USB Mini-B style end. (Male) It looks like this, http://en.wikipedia.org/wiki/File:USB_types_2.jpg It is the second one from the left side.
Where I'm at, we have Walmart stores. At Walmart they sell a USB adapter kit, made by Philips. This kit has a USB A to USB A cable, that both ends are Male. This cable is on a little retractable reel. The reel is about the size of a USA fifty cent piece. In the kit are five different styles of USB adapter ends. They just plug on that USB A to USB A style cable. (On the small reel) One of those adapter ends is a Mini-B USB male end. It has a Female USB A socket on one side, and a Male USB MIni-B end, on the other side. The kit sells for about $12 dollars.
Should you find that somehow, this USB power cable does not give enough power to your LaCie external optical burner drive, then here is LaCie.com, Products, Support & Downloads, and the Power Supply, for your LaCie DVD+RW 301230U external optical drive, http://www.lacie.com/us/products/product.htm?pid=10715
make alarm noise
