See if you can turn the blades or reach a knife balde in to turn the blades....if something has jammed them.... get it removed... if they spin feely, then the motor is bad and replacement will probably cost more then a new one...
heatman101
Unplug the grinder first and than unscrew the blade. It may be tight so it may require some effort. Do not use your fingers. Clean inside the back side of blade housing, screw the blade back in and it should work. :)
