Nikon COOLPIX L101 Digital Camera Logo
Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which batteries can you recommend, I am using rechargeable duracell, and they just don't last very long
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Nov 30, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
218923
Points
3782
You don't mention the rating of your rechargeables- this can vary a lot. Some have twice the puff of others. The rating is not always prominently marked, but should be on the battery somewhere.
NiMH batteries with a capacity of 2700mAH or more are available, and these will obviously last longer per charge than those rated 1600mAH or so. However, all things come to an end, and while Ni-MH cells are supposed to be rechargeable hundreds of times under ideal conditions, in real life they will lose a bit of capacity every time until they become a bit short of puff.
The outside temperature DOES NOT WORK
Either the outdoor sensor is bad, or it may just needs new batteries. Make sure there is no battery acid, or corrosion on the battery contacts. A fingernail file, or a piece of sand paper work well to clean battery contacts. Use new batteries. Duracell and energizer seem to last the longest. I wouldn't recommend rechargeable, or economy batteries.(They don't have as strong of charge as the other batteries.
Mar 01, 2015 • Home
FUji FinePix s1000fd, camera will not power on with new batteries, when it powers on it goes off in a few seconds or minutes indicating battery low, i have used fully charged batteries, ordinary batteries...
I have same problem as edmoze mentions above - batteries went dead. I first tried to use regular Duracell AA and it would still not come on. Went to internet & it recommended getting the Duracell rechargeable NiMh which I did. Got the charger & last nite they charged overnight. Today the camera did come on & I was able to download what I had taken. But what concerns me is that the low battery light is still flashing after a night of charging. What's up? Should I expect this kind of battery problem to continue? Seriously considering getting a Nikon Coolpix.
2answers
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
2answers
Batteries keep dying
hi
wat batteries are u using?
I have the same model, have been using rechargeable batteries as well as duracell. works good
dun buy those cheap batteries, $1.00 types, they are not enough to sustain the power requirement
Batteries
I use Duracell 2650 mAh rechargeable AA's with my 283 all the time. You may read that 1.2v Duracells or other rechargeables will not work because of the slightly lower voltage (alkalines are 1.5v).
I believe the problem lies not with the voltage, but is due to the slightly fatter profile of the rechargeables that causes a tight fit in the Vivitar battery pack. I find that, after inserting all four (the last will go in really tight), I need to give each cell one more firm push so that it seats properly into the battery pack.
Good luck.
Caruso
I have an energizer ERC161 battery manufactured by audiovox and am unable to find a charger for it.
I just used the Duracell charger without a problem. I have not tried to charge an Energizer and Duracell at the same time and I don't recommend it unless someone who has tried says otherwise!
2answers
Camera turns itself off while i am using movie mode
Use alkaline batteries like duracell. Digital cameras support only extra duty batteries.
FinePix E500. 4.1 : model # BL00402-200(1) E
Indeed you can!
I would recommend against using any of the older NiCAD batteries, however.
The newer (and - BY FAR - more efficient) standards is NiMH batteries. (Nickel Metal Hydride.)
I used to be an Energizer fan myself... But as I worked in electronics retail, I tried many different brands of batteries with our products. I actually hated Duracell because of the crap quality of their older product lines.
But eventually, I had to grudgingly admit that Duracell batteries were far superior to any other brand currently on the market. (No less expensive, however. Pretty much the same price.)
I use the 15-minute charger currently available from Duracell. It cost about $30, but it comes with 4 AA batteries with a rating of 2400 mAh.
This rating is basically what determines how much of a charge the battery can hold. The higher the rating, the longer the battery will last.
I also bought an extra pack of 4 AA's while I was at it. I bought all of this for my digital camera. (Canon S3 IS.) The batteries in the extra pack had a higher rating of 2650 mAh.
Even using the 2400 mAh AA's, my camera lasts for a few DAYS of continual use! I will admit that I rarely use the flash on my camera. But even with the flash, the batteries last several hours with continual use. The 2650 mAh batteries last even longer. (Yes. I have monitored and recorded usage vs endurance. I know. What a nerd I am, eh? :P )
Perhaps you've had bad luck with Duracell before, but so did I. I'm still not too fond of their alkaline batteries, either. Perhaps you should consider giving the Duracell rechargeables a try?
Click HERE to see the product I bought on Best Buy's site. (I bought mine at Walmart, however.) It is the 15-minute charger system. It works with both AA's and AAA's. (I had to really inspect the device after I bought it to see how it recharges AAA's though. But it works great.) It actually does charge in 15 minutes, too. Every time. It's so powerful in fact that it uses a fan to cool the batteries while it's charging. Now that's awesome. :)
Remember to make sure that you give the batteries a full charge before you use them. Also make sure that you don't charge the batteries again until they're completely drained. Otherwise you will significantly decrease the charge capacity of the battery. Duracell has an excellent guide on their site on how to lengthen the life of your batteries. (I just found it trying to look on their site for their own product...which I did not find. Good batteries, crappy web site. Bleh...)
Click HERE to see this spiffy guide. It actually contains excellent information.
Otherwise, you can try any other brand that you prefer. Energizer is still second best, followed by Rayovac. (This is from my own experiences, of course.)
Let me know what you think. :)
Cyryl
3answers
Batteries always low
If you're using regular alkaline batteries that?s fairly common. If you want longer life most people purchase rechargeable nickel-metal hydride batteries and a charger. Depending on the camera you?ll get 40 or more flash images out of a charging. I have two sets, one in the camera and one in the charger. Expect to pay about $5 to $10 for a set of four and around $10 or $20 for a charger, make sure its for nickel-metal hydride batteries and not the old style nickel-cadmium. Good luck and don?t forget to rate this post.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
