Hi, I seen that you had some suggestions for the Acer al1716. I have fixed a couple of LCD's but this one I am having trouble with. I did check all of the capacitors but none showed to be damaged. Do you have any other suggestions on what to look for?
Thanks, Jake
Jake. 2005 , 13 year old CCLF junk monitors sure.
no PC stated, so I must assume this monitor fails on 2 good PCs, so if yes, gee is a bad monitor
does the OSD work>? it must. or the monitor is bad.
caps are only part of a problem on 1999 to 2007 years
when DERP engineers used china cloned bad CAPS.
the wiki on cap plague is clear on that.
the insides has 2 cards, most do.
1 logic
1 power supply,
so if the CCFL are dead.
does the flash light test pass or fail, learn this skill on all LCD made before magic year 2010
your manual says on page 2, and I quote to you.
"Due to the nature of the fluorescent light"
SXGA 1280×1024 pixels
last page toxic Mercury Hg, CCFL.
no service tag presented by you, so no exact answer possible\but testing is MY BAG for 53 years. 1965 to now.
so does the flash light test work.?
power on, and for timer (no burn timer)
the monitor runs for 10 to 30 seconds, and will show
for 13 long ears the ACer LOGO
and then in less than 10 seconds you push mon. Menu
and OSD shows, up. it must or CCFL dead
with flash light pointed to the screen you see both
logo and OSD proving CCLF is dead, and see data now.
if not the the PSU is dead or the logic died
PSU is prime fail (due to heat)
ever see this,?
do not call me a liar if your monitor is outside USA.
or below, is only for say Europe, learn now that monitors have different PCBs in many countries by LAW.! facts.
google finds this gem in 5 second flat. ever google?
https://www.manualslib.com/manual/269397/Acer-Al1716.html?page=45
now the flashlight test
http://www.pcdied.com/monitors_and_screens/flash-light-trick.html
the #1 key factor on all monitors is RTM
RTM and see words mercury or Hg, or fluorescent
BAM you have CCFL, 2009 and older all do.
2010 LED first time.
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
I have a ACER 19" Model AL1912B and its doing the same thing as yours, Blinking Green light with a Black Screen, mine only has 5000 hours of use, if that much.
The backlights are supposed to be good for 40,000 hours, I sent Acer an email asking what they know about this problem, but I've received no response back. If anyone has an idea of what this problem is, any suggestions would be helpful...
supposed,?
no some go 20k.
and that is 5 years
10 hr '/day.
and the person above
has 10 years on the clock
