Tip & How-To about Cell Phones
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
Install the hardware for Bluetooth. If you do not have the
latest drivers, download and install them.
Insert the software CD that was provided with your mobile
phone and download the software. If you do not have this software, you can
download it from the manufacturer's website.
Turn on Bluetooth on your cell phone. Ensure that it is
visible to your accompanying devices. Also make sure that Bluetooth is enabled
in both your system and mobile phone.
Click on your "Start" button and then your
"Control Panel." Double-click on "Bluetooth Devices."
Click
on "Add Device." Once it is done searching, pick your mobile phone
from the list.
Choose any of the options on the list if you are prompted to
enter a passcode. You may also proceed without using a passcode.
Enter your selected passcode if you chose one, ensuring that
it is the same one on your phone. Your mobile phone and computer can now
communicate with each other.
Run the software that came with your mobile phone. You will
get options to "Backup" or "Sync" your phone depending on
the software and the make and model of mobile phone.
hope it helps, if so do rate the solution
