Question about Cameras
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
    Genius:
  • 1,177 Answers
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Posted on Nov 30, 2010
SOURCE:
Why wont my sanyo vc-e760 hold a charge
Since you've already tried different batteries, you have a couple of other options...
  • Instead of plugging the USB cable into the camera's wall charger, plug it into the USB port of a computer, or even into a USB phone charger.
  • Try another wall charger.
  • Try another USB cable.
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
Aug 04, 2014 | Sanyo Cameras
My laptop dont recognize the sanyo x1250
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 04, 2012 | Sanyo VPC-X1250 Digital Camera
Usb device not recognized
Assuming a healthy camera battery, capable of holding a charge - try another cable / USB port / Computer first.
When it's same on all USB ports and a different computer, wiggle the USB connector on the camera carefully. If the connection is ok at some point, it's the camera USB port making bad connection.
Jul 04, 2011 | Sanyo VPC-X1250 Digital Camera
What does it mean when your Sanyo VPC-X1250 digital camera says "System error?"
try to reset your cammera settings to default
try to change memory card first.
try to format your memory card
Jun 05, 2011 | Sanyo VPC-X1250 Digital Camera
Will a USB port charge my sanyo x1250 camera?
No. On this camera the USB port is only for transferring photos from your camera to your computer. In order to charge your camera you must use the recharger that comes with your camera.
May 06, 2011 | Cameras
SANYO VPC-T700. I cant find my manual and I dont know how to recharge the camera battery. I plugged the USB cable into my computer and nothing happens and of course I need the camera today!
I don't think you can charge via Computer USB.. you need to use the Charger plug that comes
with the camera. Plug it up into the wall.. You should charge it overnight, but i know you don't
have that kinda time
Jan 23, 2011 | Sanyo Xacti VPC-T700 Digital Camera
Lost charger to camera
Most of these charge Via USB you can purchase a replacemnt charger from the manufacture or even radioshack has universal chargers als o you may wan to check www.frys.com to see if they have one for you aswell. Thanks dont shoot the messanger and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 11, 2009 | Sanyo VPC-E760 Digital Camera
Cameras Logo
499 people viewed this question
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
