SOURCE: netgear rangemax wireless router
The thing you can do is move near the router or get a antenna.
SOURCE: Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
SOURCE: Have a new Hughes net HN9000 satellite service and
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
SOURCE: No Power to my Netgear Rangemax Next Wireless N-Router WNR834Bv2
This happens from time to time with these routers. It happenned to me with a Linksys and I found that the power unit in the router failed. One thing you could do is try a couple of different wall sockets or see if another adapter might work. Is your Netgear new enough to get replaced by the store?
SOURCE: PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
