Rotel RDV-985 DVD Player Logo
Posted on Oct 10, 2017
We have model RSDX-02e DVD Receiver. When playing a DVD the colour disappears, when black and white it is a great picture, but when the colour flicks back on intermittently, it is very speckly and a wierd colour. We could count on one hand the number of times the DVD has been used, even though the unit was new in 2004. Any answers please. Thanks
1helpful
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Toshiba 32DV502B
Hi my DVD is playing in black and white how do I fix this!!
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Magnovox dv220 mw9 plays in black and white only
Hello
The output signal's colour system to this player is NTSC. Just look whether your TV is NTSC system compactable. Check whether the disc is recorded in any other colour system, like PAL or SECAM. These are the reasons for absence of colour to the picture. Check whether the colour control of the TV is at minimum.
DVD ONLY PLAYS IN BLACK AND WHITE
figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
2helpful
2answers
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
16helpful
7answers
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Colours Disappeared
DEAR
YOUR SYSTEM IS OK ,ONLY YOU HAVE TO CHECK THE COLOUR SYSTEM MODE YOU HAVE SELECTED ON YOUR SYSTEM REMOTE .
CHCK BY SELECTIN PAL/ AUTO/NTSC/SECAM
THANK YOU
Top Rotel Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
