If you look under your dash you will see a black box very small on the arm of the break peddle. As you press the break down the switch has a small button that releases causing the break lights to come on and you release the breaks the toggle switch is pressed back in to turn the break lights off. The wire that goes to the break switch may have backed out wiggle the wire and press in gentley get some one to check the breaks if this does not work the switch is most likely bad,,,,,also check your fuses
GOOD LUCK
