I have a Panasonic SA-PT850. It has an USB, so I often watch
movies through it. I transfer a movie to my Corsair Flash Voyager GT
16GB, but sometimes there is a "lag" when watching movies. Frames
become very low. I have been told, that it is because of my USB, it
happens when the USB is to slow, but Corsair Flash Voyager GT is one of
fastest USB flash drives! Why do I have those "lags"?"
SOURCE: no sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
SOURCE: panasonic sa-ht700
Usually problems that start "out of the blue" after being powered-up for hours, caused by heat building up are due to things inside getting hotter and hotter until they fail. Unless something actually burns up, this is a reversible problem. Shut it down to allow it to cool off, and it works again. I own a SA-HT700. After 24 hours or so of being powered-on. it starts making a loud rumbling noise. Turning it off for 20 minutes fixes the problem. There's a fan on the back of the unit. It does not work. The heat sinks inside my unit are not covered with dust - suggesting the fan has never worked. I rigged an external DC supply to the 12V fan, so now the fan runs all the time. I am waiting to see if this fixes the problem.
SOURCE: DVD No Play
it did it to me i had to make sure my telly was on the right channel and the yellow video cable was in correctley at the back of the machine
SOURCE: How do I get my Panasonic sa-pt670 to play all the
I have a Panasonic SA-PT670 with an XBox 360 connected to it. This is how I configured my system for full 5.1 audio. I'm running an HDMI cable from the XBox to to the TV. I'm running another HDMI cable from the reciever to the TV. I am also running a digital audio cable from the recieve to the TV to handle strictly audio while the HDMI handles the video from the DVD/Reciever to the TV. On the reciever I configured the Surround option to "Manual --
SOURCE: I get a lag in
See page 39...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
I have a kingston 1gb usb drive that i put in and it lags in the middle of movies constantly i also heard it was because of a slow usb then i put my new 4gb in and the same thing happened, i payed a lot of money for this system and this is the **** i have to put up with
