Pull off the wheel and run the machine. you will be able to see if the hub is out off balance. if it spins true the you have a rim or tire out. this can be fixed by having a tire shop balance it for you or call Jugs and get a complete replacement,tire and rim ,shipped mounted and balanced.
it is very unlikely that the motor shaft is damaged unless it was droped trying to load it into a truck.
it most like;y is the tire and rim that is out
