SOURCE: Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
SOURCE: Beverly HIlls Polo watch needs band adjustment
All you prepare a piece of jewelry screw.There will be very tiny screw in the side of the band you better screw it carefully and when the screw is out detach it,and size it that's you like size comes out.That all if want to resize desame what did in the other side. Always do it slowly so there no scratch or visual impaired damaged.
SOURCE: Automatic watch..can I wind it to keep it running if not wornby winding?
yess you can i have one
SOURCE: winding and setting the time on a rolex watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2)
when you pull out the crown to the first click, it is in day and date
setting position (depending wich way you turn the crown).
NOTE: to
adjust the day or date, previously you have to advance hands forward,
passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m.
using the crown in position as described in chapter 3. When done - push
the crown fully in, then pull out to the first click and only then
adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To
find the daytime or night time on the watch: pull out crown to the
second click and advance watch hands forward till you pass the 12 mark
on dial. If the date changes as you pass it - it is the night time
(midnight). If the date do not change as you pass it - it is the
daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
SOURCE: Looking for replacement strap for Beverly Hills Polo-club Watch
can't reset the time on a PU103SLA0051.500
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
