Have you installed any other software recently? you might try system restore and if that didnt work,try uninstalling and reinstalling your webcam driver
you have in built web cam that's not a problem to install other web cam ..... connect the web cam and install the driver which one came with the web cam and enjoy it ...............
If you hold down SHIFT and right click on a BMP file, then select "open
with" and choose the MS Paint option. This should let you open the BMP
file and also provide an option to use as the default viewer.
if you do not know where the file is... goto start, search, for file and search for coronastart_bg.bmp
First place to start is with an updated camera driver from Toshiba's support page. Either way I would go ahead and remove the camera from the device manager to see if that solves your issue.
That is an image file, it may have been moved or deleted, looks like from the file path it's a background image. If you want a quick solution you could just re-install the software. If you're feeling techy go into MS paint (start,programs,accessories,paint) open a new image paint the background black and save it as a .bmp called start.bg then place the file in the Toshiba\corona voila you've replaced the file...
Go to support.toshiba.com and get the latest camera software on downloads.
Once you have downloaded the file, go to programs and features and uninstall the old one then after, re install the updated camera software. And by the way turn off the User Account Control off under user accounts. Hope this helps...
Please help.... to troubleshoot this problem re: toshiba satellite L310 web camera doesn't work. the light blue color sensor display but appear only black screen.
If you are trying to use live messenger 8 you may have to use the set up utility. Open Messenger, show menu, tools, audio and video set up. Checks webcam, mic and speakers. If it says webcam is being used by another application, check the taskbar. If there is a webcam icon there, right click and close. Hope this helps.
