Here's an English version I made with the help of onlinedoctranslator.com (uses Google Translate). I made a couple of adjustments but it's still pretty rough due to the machine translation.
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date 2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date 2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Hi - Zeon have the instructions for their clocks and watches in the Download section of their website http://www.zeonltd.co.uk/ Just type in the model number e.g. CE1648 (analogue-digital alarm clock)
Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
