Question about Sony KV-36XBR450 36" TV
The picture does not come on when I turn it on.
    Top Expert:
  • Sony Master
  • 76,060 Answers
Hello
Your TV is now in dead condition I should say. You should strart from its power supply regulation section itsef to rectify the fault. Look into the fuse, a glass fuse is there, in power supply board. If It has found blown, make sure that there is something short in either power supply regulator side, of on the other part of the printed circuit board.
You just place a fuse of same rating as used, if the fuse is blown. If the fule you installed newly also blows off, check first the retifier stalk for any leak. The stalk contains four diodes, even any one of them gets shorte, fule will blow up. If there is no leak in the retifier stalk, measure the voltage resistance across the main filter capacitor, a bulky one capacitor fitted in the power regulator section. If you see a full deflection on meter, it means that there is some dead short inside the power regualtor system.
Usually Sony uses STR regulated type power supplies, and some uses MOSFET [Metal Oxide Semiconductor Field Effect Transistors], as switching elements. Bothe of these types can be shorted, due to a high voltage spikes, or a sudden supply failure and restart.
Check out short test on these components, out of board, that is, desolder it out from the circuit board. You just resolder one by one and measure the resistance ad described above. Thus you can find out the exact component, that have a short. If any of these components shorted, check the entire power regulator section for any more component failure, like zener diode short, resistors opened, and so on. You should have a concept of soldering and a little knoledge in electronics. There will be a MOV [Metal Oxide Varistor] fitted across the power supply input, which look like a disc capacitor. it will get shorted when a certain voltage spike occures abvve its rated voltage, and apply a dead short at the supply stage. If any of them used, desolder it out and check for any leak, and is found leaky, replace it. It is used as a saftey measure, and without it the set will work fine.
Just check these and if you find any difficulty, contact me through Fixya. Ok.
Posted on Nov 29, 2010
SOURCE:
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
It does not shows clear picture
turn the black ring that is around the len's while your cam is on and you can see a picture. ...the black ring will focus your lens. turn till you get a clear picture...turn either one way or the other till picture clears up
Aug 30, 2009 | HP USB Web Camera
DID NOT SHOW THE VIEW TO TAKE PICTURE INSTEAD IT
I THINK ITS A MEMORY STICK PROBLEM. PLEASE TURN OF YOUR MEMORY STICK AND TAKE PICTURE AGAIN . I THINK IT WILL BE WORK.
MY ADDERSS IS : bony_don@yahoomail.com
Mar 13, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Picture won't stay turned
You would need to correct the orintation using a computer then reload the pictures in the frame. The frame is reading those pictures as how they were originally created.
Dec 27, 2008 | Kodak EasyShare SV811 (8858946) Digital...
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Sony KV-36XBR450 36" TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
