I have had this unit for a year and only used it for capturing into my computer with dv tapes. This week I decided to run some video into the HDD 40gb drive. This worked fine, played back fine from the HDD. When I went to dub to dvd, it burneda dvd but with pixelation on playback. Went back and adjusted settings to higher bit rate on burn.... worked ok. still some problems in the dvd though. Decided to go ahead and make a few more copies of this, but now everytime I try to dub onto dvd the dub stops a few minutes into the dub. Also tried to use the fast burn, this dubbed through the entire project but then would not finalize the disc. Anyone else have similar problems?
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd Never record more than 2 hrs on a disk there are programs for a work around that reprocess the dvd vob file with adjustments for the sync. could also be a hardware problem is your mini dv long play source as well?
It sounds to me that the damage was created prior to you attempting to capture the video.
There are several ways to help prevent these issues.As a rule I would suggest only to use miniDV cassettes to record only once, as they are prone to errors such as you describe.
Also, keep the tape heads clean and inline. tape heads have a limited mileage and need to be replaced after a while.
We all become victim to the mosaic problems you describe, and it can be repaired on the computer, although it is a painstaking manual process.
If you have footage that is damaged in this way and you really feel you need it repaired, please contact me, I will be happy to offer my services.
1. Insert a blank DVD disc in the DVD deck and close the disc tray. 2. Insert the VHS video tape you wish to copy into the VCR deck. 3. Find the place on the VHS tape from which you want to start dubbing using the PLAY, FF, REW and PAUSE functions. For best results, pause playback at the point from which you want to record. 4. Press the DUBBING button on the Remote Control or DUB on the front panel. The Dubbing menu appears. 5. Use the arrow keys to select the desired Record Mode: EP, LP, SP or XP. 6. Select [Dubbing] then press ENTER or DUBBING to start copying. 7. To stop dubbing at any other time, press STOP (x). Dubbing will stop automatically when the VHS tape ends.
