Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
When you open the door, do you hear the fan come on? Do you have a frost building up on the wall?
