If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the installation and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Also after you install the program you most likely will have to do the same for the application file.
SOURCE: I can not install Learn
Try running the program in compatibility mode. Right click on the icon used to start it, go to compatibility and change it to Windows XP. If this doesn't work, the program is not capable of running in Windows 7 so you will need to downgrade Windows or upgrade to a newer version of the Learn to Speak English software.
