Audio Technica AT2035 Professional Microphone Logo
Posted on Nov 29, 2010
Hi i am using the audio technica at2035 condensor mic and the m audio mobile pre 2nd gen. audio interface. yesterday the mic was working fine with no problems but today for some reason i have to really yell loud into the mic to get sound to the computer but even then, you can barely hear anything and theres always little crackling sounds coming out of the speakers. can someone please help?
A
Anonymous
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
New mic. does not work
Have you got phantom power enabled?
I have tried running my AT2035 through a preamp and direct into my interface and am having the same issues with an extremely blanketed & muffled sound on vocals and instruments. Originally thought...
This mic has a 10db pad or attenuator switch at the base of the barrel maybe you clicked it on by mistake,
Try changing the lead.
The power supply on you preamp may be failing or had the voltage selector also clicked to the wrong setting.
These are cheap things to try before spending money.
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
3helpful
2answers
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
2answers
Problem with CVL-1064
Sounds like the port/ soundcard has issues.
My advice to anybody using mics wich plug into soundcards is get an interface mic pre and a real mic. Interfaces can be had for cheap these days as long as mic pre quality doesn't matter to you, and you can get a shure sm-57 mic for $80 wich will last a lifetime.
Microphone distorted
is this a power mic? check with a back up mic if it does it with the backup its not them its past them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
1helpful
Want work
You need to fine tune (to connect wirelessly) ur wireless mic to your wireless receiver unit. Put a fresh battery to ur Mic then power-up ur receiver unit, find the right channel for both unit.
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
