Honestly, it sounds like there might be a RAM issue. Personally, I would remove all the RAM chips (assuming that you have more than 1 installed). Then Place 1 Chip in and check to see if the machine boots up. If yes, great.. 1 good chip, shut down, remove chip, try another one. If still No, shut down, remove chip, try another one. Please keep in mind that some of the older systems especially need to run in pairs, so you might have to try different combinations of 2 to see if this is the problem. Hope this helps.
SOURCE: Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
SOURCE: quadcore installation on asus p5n-e sli motherboard
this site is useless. get the links straight!
SOURCE: i have a p5n sli motherboard which refuses to boot
Go to page 2-30 section 2.4.5 in your manual.
If you are using the onboard graphics for your display set this to [PCI]. If you are using the PCI-E video card, set the bios to [PCI-E]. Save & exit the bios. You should have display after the system re-boots. If you still have no display & you are 100% sure your monitor functions than the video controller on the board is bad. This can not be repaired.
Mike
SOURCE: Can a p5n-e sli handle a single 9800gtx? I
Yes as long as the 9800gtx is PCI Express x16. I am assuming the p5n-e is the Asus MB. Since I couldn't find any other Manufacturer using that MB#
Testimonial: "Thanks for the info. All pcie 2.0 are *supposed* to be backwards compatible with x16. We shall see."
SOURCE: drivers for p5n-e sli motherboard
You can download the drivers here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the upper left hand corner of the screen, type in the model number of the board (P5N-E SLI) and use the drop down to select a category (probably "All"). Good luck.
