SOURCE: whirlpool side by side water dispenser not working
I had the same problem and it appear the cable set between the freezer door and refrigerator body has some wires broken. The cable is in the bottom right hinge. You can try moving the cable with fingers at the same time you're pushing the water lever.
While this is not going to be a permanent fix, at least it confirm where the problem is.
SOURCE: Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
SOURCE: Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
SOURCE: MY SIDE BY SIDE Whirlpool
A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced.Thanks.
