Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Posted on Nov 28, 2010
Leaking from the bottom after removing something that got stuck in the spinning peace
A
Anonymous
Check a couple things.
Use paper towel and see if top of disposal is damp or wet. The basket strainer might have come loose and water is leaking down.
Fill sink and then release water all at once and check strainer basket and dishwasher hose.
Check where tubular pipe connects to side of disposal. Sometimes this joint can leak, and then water appears at bottom of disposal.
If top of disposal is dry and tubular pipe is not leaking, then disposal is suspect.
Disposals rust out, and dislodging something from cutter plate can open final crack.
If basket strainer is leaking, and disposal is older than 5-8 years, you might consider new disposal since disposal has to be completely removed to reseal basket strainer. See link below for basket strainer steps.
If it comes to this, I wrote tips for installing new disposal
http://www.fixya.com/support/t6995519-badger_1_2_hp_in_sink
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
What is error 09,038,46:3794? How it can be fixed?
This error means something is wrong with the ink loader.
Sometimes a flag gets jamed or broken when you use third party ink or when you use peaces of ink. You can try to remove peaces of ink that are stuck in the inkloader shaft if you this does not help then you will have to replace it.
part# 133K27710 good luck
7helpful
2answers
Clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
1helpful
Hotpoint aquarius washer dryer!
The water is coming out of the dispenser because it is going into spin with water in the drum due to it not draining properly.
So you need to check the filter.
If there is no filter at the front bottom of m/c, then you need to remove the lower rear panel on the m/c, locate the large black hose going to the bottom of the drum, undo the clip[ securing hose and remove hose.
There you will find the filter, remove and clean.
Check the pump at the same time for any obstruction.
Refit hose, making sure you get it on properly.
Test for leaks before fitting back panel.
Plz rate this solution.
thanks.
2helpful
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
1helpful
3answers
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
Ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Washer spins slowly & won't drain
Look at the bottom of the front panel. There on either side is a philips head screw. removing these will release the front panel. the upper part may have spring clips to the top. clearly it is nearly impossible for a sock to get stuck in the pump as the water drains out through all them tiny holes in the drum. look for a broken belt. there should be two of them. the motor is in the left front portion of the washer and is spring loaded to push out from the center.
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
