Opened the interface page(192.168.2.1) in your internet explorer.
Right Side click on security> password field make it empty>submit>U can see your password. otherwise , uncheck on obscure PSK> now u can see.
Still, if u have problem, call belkin 1800 2BELKIN. U will get lifetime phone support from belkin and its foe 24*7...
That depends. If you have physical access to the router, plug any computer into a LAN port with a networking cable. Re-boot the computer.
Goto Start > Run (or type in the search box)
cmd
Hit enter.
You should see a black command prompt.
Type in: ipconfig
and hit enter. You will get three sets of four groups of numbers: IP Address, Subnet Mask, and Gateway.
Open up your web browser and type in the gateway address in the search bar. It should take you to your router's home screen. From here you should be able to find the wireless section and reset the password.
SOURCE: network security
Once you've logged into the router (open your browser, and type ONLY this into the Address line, without the quotes: "192.168.2.1). You should get a log in pop-up, "admin" is the username, and the password is left blank (or is sometimes "password"), again without the quotes.
Once logged in, you have a series of menus on the left hand side, Usually large blue lines demark each section, i.e. "Lan Setup", "Internet WAN", and of course the section you are looking for "Wireless". Under each header is listed each of the pages available for that function. For example, under Wireless you'd want the first 2 items: "Channel and SSID" - this is where you set the name of the wireless network; and "Security", which is where you setup whichever one of the Encryption options you want. This Encryption key is the password you will use when connecting wirelessly to the router from a PC.
Hopefully that is enough to get you setup.
SOURCE: belkin router , I need to find my network key
192.168.2.1 is the web access page for the belkins router. You can also just download the software from belkins website for you model of router. Run the program and redo the network key.
Let me know
comier957
SOURCE: How do I security enable my Belkin router?
Connect a computer to any one of the four LAN ports of the Belkin wireless
router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default,
the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the
page to login to the router. By default
the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination
of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You
may also enter a pass phrase and have the router generate a key for you. Example
(0102030405060708090a0b0c)
Apply the
settings.
Please write down the key – You will need it later to configure
your wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you
router and change the setup and admin password.
/regards
Teis
