Dont answer this but,,,,what are you flushing down it,,,,??? do you have a good flow of water in the flush,,,as it should flush away most normal things and by the way,,,children dont fit down the loo? i tryed that years agow! ooow! check that the out let pipes are clear and free flowing with no lips sticking up into the out let pipes
Ah good one. Mentioned to children in case you thought we had a tricycle down there! Confused by this statement: Check that the outlet pipes are clear and free flowing with no lips sticking up into the outlet pipes. Outlet pipes? Are these in the tank above the bowl? Thanks.
if water will not flush away fast it has to be a blocked pipe or back presher in the outlet pipes so check the pipes that go out to the swears if any thing like (a tampon's or lady's thing's in a plastic bag?) or some thing like that got stuck with the end sticking up any thing going down the pipe could rap around it and clog up the flow,, this would cause a back presher and stop water from flowing away fast,, its the only reson the loo wont flush away,,the water is being held back,,,,i found a dead bird (a gull) stuck in an out let pipe once????
hope this has given you some help, mike
