What make and model camera? Bear in mind that your 16GB card is actually an SDHC card, not an SD card. Some older cameras and card readers will only handle SD cards (2GB or smaller) and not the higher-capacity SDHC cards.
Hello Gerri, If you double-click on the folder do you see the photos as a thumbnail image ? If so you can transfer them yourself. Best Regards, Russell
Hi sfarmer1983...
Plug your SD card into an SD card reader...the plug the card reader into the computer.
The computer will recognize the card reader and open a window...you will select "see files"...
Highlight the songs and put them in Windows media Player...plug your mp3 player in while the computer is running and Media player is running...Media player will recognize your mp3 player
Highlight your songs in the SD card reader...drag and drop the files to Media player...
Please take time to rate me
This is not normal. Try turning off the PC remove the sd and start it again. If no beeping put the sd card in the reader again. If you still have problems post back.
I speant Hours swearing at my phone because it would not read my music
files, Tried the card on many different phones which would take Micro SD
and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro
sd card in that and then putting your music files into the "sounds"
folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds
folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents,
Sounds, others and Videos on your Micro SD card. Format the card by
going My computer, Right click the Card reader (with you Micro sd card
inserted) and click format. Takes a few seconds. Insert the card into
the phone, the phone will auto put the folders on the card. Then go to
step 1 (above) and start again.
Using a USB SD card-reader, copy all the photos from your camera SD-card to your PC, then try format option in your camera, this way the photos in your SD card are safe(in the computer). OR insert a new/empty SD card into your camera. Use the format option and start clicking photos.
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue. To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Follow these steps:
1. If you have a SD card reader, insert the SD card and look for it in Windows Explorer. In this case, mine was labeled F:
2. Right Click on the drive for the Card Reader (IMPORTANT) and choose FORMAT.
3. Format card with default settings.
4. Turn Camera on and go to MENU> FORMAT CARD
5. Before answering the next question, insert SD card into camera. You will hear it beep twice.
6. Choose FORMAT and the card should be formatted for use on the camera.
Cheers!
PC Model and OS needed.
