Sierra International 18-6756 Marine Power Tilt and Trim Motor for Johnson/Evinrude Outboard Motor () Logo
Posted on Nov 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on how to fix?
Nic McCully
Level 2:
  • Expert 195 Answers
  • Posted on Nov 30, 2010
Nic McCully
Expert
Level 2:
Answers
195
Questions
0
Helped
58346
Points
646
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
1helpful
Hi, The tilt / trim runs very slow up & down after motor made minor impact. Motor is a 1998 Oceanpro V6 225. Your advice is appreciated, Thx Ted
With the issue being in both up and down, You may have bent the tilt/trim shaft(s) .. this is a job for a professional!!! sorry..
1996 70 hp johnson outboard, when put in reverse the motor lifts up when given a little speed and goes back down when you let off
If it does not have Power tilt, the tilt lever is either not in the run position or the mechanism is bound up. Look for a hook shaped that engages your tilt rod (the rod that sets the tilt angle in the 4 or 5 holes in your transom bracket. BTW no rod, no reverse lock.
Jun 26, 2015 • Boating
Can't get any power to my evinrude tilt and trim what am I doing wrong ?
Check fuse.try connecting trim wires from t/tilt motor direct to battery supply to see if motor is ok.t/tit solenoid could be faulty,switches could be faulty.broken wire in loom or control box
77 70hp Johnson with no power tilt-trim. Can't raise with tilt-run lever
screwdriver lift locking arm on lock down rod and lift motor
Mar 28, 2013 • Boating
How to raise manual tilt johnson (no tilt trim)
on the right side of the motor there is a lever that says tilt on it pull it up unlocks motor grab the top of motor and pull with all your mite
Mar 25, 2013 • Boating
Power tilt and trim has no electric power to it?
I had the same problem with my 50HP 1998 Johnson outboard trim and tilt. What I found, after removing the trim and tilt electric motor, was that the brush holders and brushes had gummed up to the point where the brushes were seized up and no longer making contact with the armature's commutator. Fixing this problem is rather simple. Before starting, note that it could be wise to obtain a few inexpensive parts that may need replacement: the large O-ring between the tilt motor base plate and reservoir housing, and new motor brush springs. Even without these parts, you can at least do a temporary though effective repair if you need use of the boat right away, and I'll explain how.
To get started, first you need to loosen the small pressure relief screw, to left of the larger drain plug screw on the tilt/trim fluid reservoir base. Loosen about 2 and 1/2 turns. Then you can manually tilt the engine up and engage the locking lever to keep the engine raised.
You should be doing this with the boat out of the water and on a trailer on dry ground. Lay out a drop cloth on ground, beneath the tilt/trim unit to catch any screw that might fall when removing the tilt/trim motor, as you probably will drop one and it will be almost impossible to find without the drop cloth in place. Looking at the tilt/trim motor housing, you will notice that there are three small screws which fasten the housing to the base plate, and 4 larger phillips head screws that fasten the base plate to the fluid reservoir. You want to remove the 4 large screws. Getting at the two screws behind the tilt/trim motor is the hard part with the engine attached to the boat, but it is made relatively easy by using an appropriate tool. I used a 3/8 inch drive socket with a driver extension, fitted to a socket of the correct size to insert a large phillips head drive bit. To prevent the drive bit from falling out of the socket, I used a dab of silicone sealant inside the socket before inserting the drive bit. Here's a photo of the tool I used:
This tool would have been better suited for the job if it had been a quarter inch shorter. I had to lift the engine a bit more, to gain clearance, by placing a wedge under the locking lever. For each of the 2 large screws behind the tilt/trim motor, apply a dab of silicone sealant to the tip of the phillips driver bit before removing the screws. This will help to prevent removed screws from falling, though you may still have one or both drop. If one or both fall, but don't fall to the drop cloth, use a magnetic pick-up tool to fish them out before attempting to remove the tilt/trim motor from the fluid reservoir, otherwise a screw could fall into the reservoir and be difficult to remove. With all the screws safely removed, you can now lift the tilt/trim motor away from the reservoir housing. It is fitted to the housing snugly, so you will probably have to gently tap against the motor housing a few times before it will budge. Here's a photo showing the underside of the motor, with its baffle and motor shaft pump drive socket in place.
If you don't see the motor shaft pump drive socket as shown in this photo then it will either be found attached to the hydraulic pump, or may have fallen into the fluid reservoir, in which case you will need to find and remove it. You will need to carefully remove the large rubber O-ring that you see here surrounding the round baffle plate. With the tilt/trim motor removed, the pump reservoir is now exposed as shown below, and you should cover the reservoir immediately to prevent any debris or insects from falling into the fluid. Notice that the hydraulic pump's drive shaft, which the drive motor's shaft socket fits over, is shown at the center of the reservoir. I removed fluid so that it would be visible in the photo.
After you cover the reservoir to protect it, you can remove the round baffle plate from the tilt/trim motor base, and you can remove the motor housing and armature from the base plate after removing the three small phillips head screws. Next, remove the brush holders from the base plate, and what you see will look pretty much like the photo shown below. You will notice that there is some rust and corrosion where some water had evidently leaked in past the large O-ring. You'll want to remove the rust and other deposits from the housing and the brush holders, and you can also remove the reddish-brown plate seen here to clean beneath that.
If either or both of the brush holder springs is damaged, they will need to be replaced. For an effective yet temporary repair, until you can obtain the correct springs, either visit the local hardware store or take apart a few ball point pens until you find a similar diameter spring that you can use. I actually cut such a spring in half to get two springs of appropriate length. Notice that the tips of the brushes are curved to fit against the armature's commutator, and when reassembling them into the brush holders you want the curvature to be properly placed. With the base plate ready for reassembly, grasp the tilt/trim motor housing in one hand, as shown below, and pull the armature out of the housing. It will require that you pull ******* the armature, because the housing's field magnets want to keep the armature in place.
With the armature removed, wipe clean the interior of the housing as well as any accumulation on the armature. Lubricate the bearing surfaces at both shaft ends. Clean the commutator with some 400 grit wet-or-dry sanding paper so that it shines as seen above and push the armature back into the motor housing. Now you're ready to reassemble everything. Reattach the motor housing to the base plate, making sure that you hold the brushes into the brush holders, against brush spring tension, to prevent damaging the brushes. The mating surface of the motor housing to base plate, as well as the mating surface of the base plate to pump reservoir, should have a light bead of silicone sealant applied, as we've already seen that without that the unit is prone to some amount of water leakage. Don't tighten the screws fully, as you want to allow the sealant time to cure before doing so. This will give you a better seal. When reinstalling the tilt/trim motor with attached base plate into the pump reservoir, carefully line up the drive socket of the motor shaft with the hexagonal hydraulic pump shaft so that they will come together properly. Since the base plate fits snugly in the reservoir housing, you won't be able to turn the base plate to obtain alignment. Tighten down each of the four large base plate screws slowly and equally to draw the base plate into the reservoir housing evenly, but don't tighten all the way until the silicone sealant cures. Then tighten the 4 large screws and the 3 smaller ones, and you're power tilt should be ready to go after ensuring that the fluid is topped off. Top off the fluid and retighten the screw shown in the first photo before unlocking and letting the engine down with the power tilt. You should raise and lower the power tilt several times to purge air from the system. Air is purged by loosening the smaller screw in photo #1, and then retightening it after you hear the air escape, after which additional fluid should be added with the large upper screw of the reservoir housing removed and then replaced.
6helpful
How to service a tilt/trim on a 50 hp yamaha outboard. I think the fluid is low as the trim will leak back down after raising the engine.
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Aug 31, 2009 • Boating
Top Sierra Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Sierra Boating Expert? Answer questions, earn points and help others
