So you want find a video converter to convert your video to avi format? I suggest you Leawo Free AVI Converter, and not merely helps to convert videos in other formats to AVI, but offers quite a wide range of powerful attached functions!
Use media converter free download
Joyoshare Media Cutter supports to convert avi files to any other formats. Take converting avi to iPad as an examole. What you should do is just 3 simple steps.
Step 1: Drag and drop avi files to Joyoshare
Step 2: Click Format>Encoding mode>Device>Select iPad or iPad Pro or iPad Air, etc.
Step 3: Click the Convert button on the main interface
Then a avi video will be converted to a format compatible with the iPad.
If you need a tool to convert avi to other format like mp4, you could use Leawo Video Converter to do that. https://www.leawo.org/tutorial/avi-to-mp4-avidemux-1334.html
Look, there are a lot of converters that can help, it just depends on what format you need to convert to avi. i found only one free one, it's mp4 to avi converter http://freemp4toaviconverter.com/
However, the AVI files were never intended to be shared online.
Compared to more modern formats like MP4, AVI files are significantly
larger in size and an AVI collection requires much more disk space.
Most AVI files were stored online and were available for download, instead of for video streaming.
Sometimes, you may want to convert AVI to other format, such as mp4 (iPad, iphone supported format), flv , mkv etc. you can use Free video covnerter finishing it.
SOURCE: My Teac lcdv3256hdr television wont
AVI is just a container - a wrapping that holds together a video and audio file. Make sure that the codecs used to create the video files are the ones that are listed as accepted by the Teac - DivX5 and XviD1 and 2. For that install this program in your pc
http://mediainfo.sourceforge.net/en
then use it to analyse the files.
Final test is to put one of those files in a memory stick and plug it in the tv - if the files are recognized and played from there then the Astone disk is either too large or incompatible with your tv - it happens. Use another smaller disk.
SOURCE: ive formatted my 8gb flashdrive
AVI is just a format - the video inside it can be coded using just about every codec. That sharp supports files that are coded using DIVX 4 to 6 and XVID 0.8 to 1.3. You must make sure that the avi files were coded correctly. For that install this program and use it to check the files
