Your software label template does not match the size label your printing on. Make sure your label size IE: 2.25" x 1.25" matches the template size in the software, then perform this calibration: TLP 2742 is printing blank labels
Are you using the correct labels?
Direct Thermal Printers use different labels than printers with ribbons.
If you print a label using labels from a ribbon printer in a direct thermal printer they will come out blank.
I assume by double tags you mean 2 labels across the roll. You need to tell your software that the roll is 2 across. If using the software that comes with the printer, Zebra designer. Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
Whoai restart
