SanDisk Sansa m240 MP3 Player Logo
sheldon Gilden Posted on Nov 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our San Disk m240 drains the battery even when in an "off state" and does it not start up at power on where it left off when powered down-- Our smaller 500MB Sand disk (m230?) have has no such issues... is there an upgrade sincerely [email protected]
Anonymous
Level 2:
Sergeant:
  • Expert 269 Answers
  • Posted on Nov 28, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
269
Questions
0
Helped
65417
Points
848
It wont keep a charge indefinitely mine keeps a charge for a few days in a powered off state yes you can update google sansa updater
2006 G6 GT sedan, was parked a while and battery died. Replaced the battery and started engine no problem, ran for a half an hour. Next morning tried to start but wouldn't even turn over. Plenty of power...
YOU NEED AN AUTO ELECTRICIAN TO LOCATE THE BATTERY DRAIN & OR BAD CONNECTION . THE TRUNK LIGHT MAY BE STAYING ON WHEN THE TRUNK IS SHUT, ALSO THE ALTERNATOR CAN CHARGE THE BATTERY, WHILE THE ENGINE IS RUNNING, BUT IF A DIODE IS BAD IT CAN DRAIN THE BATTERY WHEN THE ENGINE IS OFF
tip
How to increase the life of the laptop battery
Below mentioned are the suggestions that may help you achieve optimum performance from your battery.
1. We all know how wireless activities drain our device’s battery. They consume significant power even when not in use but left ON. So when on battery power, it’s advisable to turn off wi-fi and bluetooth services.
2. Say no to Screensaver: For best battery life, switch off the screensaver.
3. We should reduce the screen brightness to the lowest comfortable level in order to gain some extra battery life.
4. Unwanted Sounds: Try to mute the speakers volume and avoid using multimedia software for better battery life. Also you can avoid sound schemes which are installed which may reduce your battery life.
5. USB devices and other external peripherals should be shut and removed if not in use. For instance, charging an iPod while on battery, unless very essential, is a bad idea. The same goes for removing any CD or DVD when not in use.
6. Whenever our system runs out of RAM memory it uses virtual memory resulting in hard disk use, which is relatively a less efficient option in terms of power consumption. However, it goes without saying that additional ram does consume energy too so this advice suits best those users who often find themselves in need of extensive virtual memory.
7. It’s a good idea to shut down background programs to reduce CPU usage, say for instance desktop search applications.
8. Avoid using the plug-in DVD rom / external drives which generally runs on batteries. You can transfer the content to the hard drive or you can also run virtual drives like Pismo File Mount, Daemon tool or even Microsoft’s Virtual CD ROM Control Panel.
9. Optimize your power options to get maximum battery juice. The notebook should try to shut down the hard disk and put the display to sleep whenever idle.
10. For a healthy lithium based battery, it’s advisable to keep the electrons in motion occasionally. It’s not absolutely healthy to keep it plugged in all the time. Ideally, one should let it discharge fully at least once a month to keep the battery juice flowing.
11. When on battery power, say in a flight, use one application at a time. Ideally shut the email app once you’re done with it and then turn on the word processor.
12. A defragmented disk puts lesser strain on the battery and hard disk, so make your disk drive as efficient as you can by performing defragmentation regularly, say once every month.
13.Hibernating retains your system state as you last left it. So it’s more energy efficient than even shutting down the computer and booting it all over again.
on Feb 16, 2010 • Computers & Internet
2answers
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SAn Disk Sansa mod m240
in the settings menu on the mp3 player you will see a usb setting (hopefully) you have to change the settings in there and it should work hopefully
Frozen
there was a small watch battery that obviously powers the saving of settings.
replace it
MP3 San Disk m240
click on "My Computer" on desktop and then find your removable drive letter. Click on that and you will see everything on your device, I promise.
1helpful
2answers
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
4answers
Freezing
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line. We do apologize for any kind inconvenience this issue is causing you. For verification, does your computer have Windows XP as its operating system? This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution. Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding. If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer. Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer. To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data. Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears. After formatting the Sansa m240, please do try your Sansa m240. If applicable, please go the link below to download the firmware update for your Sansa m240. The link is: http://www.sandisk.com/Retail/Default.aspx?CatID=1326 or http://www.sandisk.com/Retail/Default.aspx?CatID=1376 If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer. NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
