Hai. I am one of the user of wii....... i
also got many problem like this..... i solved my problem using wii repair
guide....click here to help you........
1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic. If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3. To connect your Wii via a wireless connection:
If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
Make sure your Wii game system is turned off.
Attach the Wii Lan adapter to the USB port on the back of your console.
Connect the other end to an ethernet cable that goes to your router or modem.
Turn your console back on.
To connect your Wii via a wired connection:
Go to the Wii Menu.
Click on the round Wii button on the lower left corner.
Click Wii Settings.
Click the right arrow to go to page 2.
Click on the Internet button.
Click Connection Settings.
Click Connection 3.
Click Wired Connection.
Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
Go to the Wii Menu.
Click Wii Settings.
Click Connection 3.
Click Wireless Connection.
Select Search for Access Point. Click OK.
Select the access point you want to use. Click Save and OK.
You may be prompted to enter your password.
Your Wii should now be all connected.
SOURCE: what do i need to get internet on my nintendo wii
All you need is a wireless router. The Wii comes ready w/ WiFi. We installed a Linksys WRT54G2 router and hard wired to one sons xbox and Wii connects via WiFi. The router was about $45.00 @ Best Buy.
SOURCE: I have Internet in my home and a Nintendo Wii. I
Make sure that you do have a router hooked up so you have wireless internet...after that let me know what the code is and ill try my best to help you out.
SOURCE: What does error code 52030 mean on the Internet
It seems that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
To fix this issue, make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
For more assistance visit this link for further router troubleshooting tips.
Hope this helps!
