KADIO KD-725a manual:
NOTE: on some models buttons START, LAP and MODE are named D, S and M.
Time is defined as 12 hour - AM and PM. 24 hours mode is not available.
SET TIME: Press MODE 3x. Select item with LAP, set value with START.
Finish: press MODE. (return to normal mode - displayin time)
To view date press START.
SET ALARM: Press MODE 2x. Select hour or minute with LAP. Set value with START.
Finish: press MODE.
You can switch alarm on/off pressing both buttons START and LAP together. Status is displayed as a simbol of alarm clock.
STOP RINGING: Press START or LAP to silent alarm. It will ring again after 5 minutes (snooze function). If you dont want alarm to sound again, you should completely turn it off by pressing START and LAP together. Don't forget to turn it on again to wake you up at the next morning.
NOTE: When setting alarm some simbols of days in the week will flash. I can't found any funcionality of this. Obviously alarm can not be set on different day, only for every day.
SPORT MODE - STOP WATCH:
Enter: Press MODE 1x.
Start/stop/pause measuring time by START.
Set time to zero: Press LAP
Return to normal function (displaying actual time): press MODE 1x.
Note: Value of measured time will be saved, until you press LAP. You can jump from normal mode to reenter saved value by pressing MODE once again and continue to measurin time of
your sport activity.
NOTE: Some models have backlight. Models with only one AAA battery have no ligt, on the top is only a metallic strip instead of switch.
unfortunately there is no online access to KADIO. One thing is for sure: M stands for MODE; S stands for SETTINGS; D probably stands for DAY/DATE. To set the watch first you have to push the S, then choose the M and then goes the rest. I can't give exact directions, as this is Chinese made watch and no details can be obtained.
i think its kadio 3810,and to set keep the mode key pressed for few seconds until the digits start blinking then use up and down key to set values ,press mode key to switch.i hope it helps.
i do not know how to fix the time and the date and month in Kadio KD-3809 Digital Wall. Can you please help me? My son just lost the brosure and i am trying to fix it but I can not do it.
Thank you!
