Refrigerators Logo
Anonymous Posted on Nov 27, 2010
How do I access and remove the thermostat from a U-Line Wine Capitsn model # ULN 15WCSS?
  • 2 more comments
  • Anonymous Dec 09, 2010
    Sorry, but "Rrad the F**King Manual" is not the answer I was looking for. Plus, I can't even finf where to get the repair manual on Uline.
    Chris
  • Anonymous Dec 14, 2010
    My root problem is that the wine coller isn't cooling aymore. The light works fine but I don't hear the compressor fan run anymore.
    I suspected it may be a bad thermostat.
  • Anonymous Jan 22, 2011
    Hi ZJLimited, your soultion was correct! It is the thermostat - once I bypassed the t-stat, it ran fine. My only remining issue now is getting to the rear of the unit to remove the long wire (which is assume is a thermometer). Does it connect inside the cooler itself?
  • Anonymous Mar 25, 2011
    ZJLimited, I finally got some time to replace the thermostat; it's a bit of work to get to the end of the thremo behind the cooling plate inside the unit. But, it now works fine.
    Thanks for the pointers.
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Dec 20, 2010
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14450204
Points
60858
Most likely the Thermostat is bad not bringing the unit back on; the Thermostat is the temperature control knob located in the toe grille of the unit.
Removing toe grille you will see a little box that houses the t-stat. If you wanted to test to be sure just remove the 2 wires that are connected to the thermostat and conncet them together to make sure compressor and fans start up.
Hope helps.
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Dec 05, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071285
Points
27242
To learn how to remove the thermostat go to the link below and order a service manual
http://www.u-line.com/customer/
Good Luck
1helpful
U-Line ULN-15WCSS-00 Built In Wine Storage Refrigerator. How to remove and replace wine racks in ULN-15WCSS-00 please.
Question edited for clarity, maker.
Question moved from Watches to U-Line Wine Fridge.
They are usually an expanding plug. You push it to the hole and press the central pin. If you can grip it with pliers, you can pull it out. The other way is to use a nail punch and push the pin all the way through, pull out the support and retrieve the pin from the insulated cavity.
https://www.amazon.ca/s?k=U-Line+wine+fridge+shelf+support&i=tools&crid=6P110ETE4YHD&sprefix=u-line+wine+fridge+shelf+support%2Ctools%2C69&ref=nb_sb_noss
https://www.google.com/search?q=u-line+wine+fridge+shelf+supports
1helpful
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
2helpful
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
2helpful
2answers
I have a u-line ULN-WH95TP-03 THAT WILL FREEZE ICE BUT WILL NOT HARVEST THE ICE. I HAVE MOVED THE THERMOSTAT AS WARM AS IT WILL GO AND IT STILL WILL NOT HARVEST. IF I MANUALLY MOVE THE TIMER JUST A LITTLE...
Your thermostat is what advances your icemaker. You have 3 wires. When it calls for freeze then yellow(2) and blue/black(3) is closed. When that is satisfied the compressor and fan cycles off then the yellow(2) and red(1) is closed. This calls for the icemaker to advance. Red goes to icemaker, yellow is common, and blu/black is for the fan and compressor.
Hope this helps you. I would replace the thermostat
2helpful
3answers
U-Line 15WCSS (wine refridgerator) not working.
most likely the thermostat is bad not bringing the unit back on. the thermostat is the temperature control knob located in the toe grille of the unit. on the u-line unit replacing the control can get kind of involved but if you will follow the directions supplied with the part yyou can do it your self.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
