Question about Texas Instruments BA-II Plus Calculator
PV and FV problem, result not like in manual
I've just received my TI BAii Plus calculator this morning, and started to follow the instruction in the manual until I got this problem. It's about computing value in savings and computing present value (p.28 in the official manual).
This is the example 1 printed in that page: If you open the account with $5,000, how much will you have after 20 years? (with the given interest rate is 0.5% per year)
And the instruction :
20 [N] ---> N = 20
.5 [I/Y] ---> I/Y = 0.50
5000 [+/-] [PV] ---> PV = - 5,000.00
[CPT] [FV] ---> FV = 5,524.48
I did the same, and got the result : FV = 5,041.83. I didn't do anything differently from the instruction.
The 2nd example in that page is about computing present value: How much money must you deposit to have $10,000 in 20 years ? (the interest rate is still 0.5%/year)
And the instruction : 10000 [FV] ---> FV = 10,000.00
[CPT] [PV] ---> PV = -9,050.63
I followed that in my calculator, and I got PV = -9,917.03.
I tried hard reseting my calculator, but it still got the same mistake. Is that my calculator's fault ? What should I do ?
  • cheesvo Jun 24, 2008
    Oh, I got it ! The default P/Y is 12 while it must be 1 in those 2 examples. Texas Instrument should make an adjustment here in their next edition.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You have the payments-per-year set to 12. For this pair of problems, it needs to be set to 1.
Press 2nd [P/Y] 1 ENTER.
Posted on Nov 26, 2010
SOURCE:
How do i enter the pv and fv
Did you check in the manual if the calculator is able to do Time Value of Money calculations? Well it is not able to do so. Sorry.
Oct 08, 2013 | Texas Instruments TI-30 XIIS Calculator
E just received my TI BAii Plus calculator this morning, and started to follow the instruction in the manual until I got this problem. It's about computing value in savings and computing present value...
I have carried out the same calculation on the CASIO CFX- 9750GPLUS and I got 5524.478.
The only explanation I can think of is that you forgot to clear the worksheets before doing the calculations. You should reset all variables to defaults. To do so, press [2nd][RESET][ENTER].
Jun 19, 2011 | Texas Instruments BA-II Plus Calculator
I am using Texas BAII Plus. The problem is when I try to calculate the NPV, N, PV,PMT, FY. it does not provide the right figure. It was ok until this morning. I think I might press something wrong....
Check the BEGIN/END setting (2nd [BGN]) and the number of payments per year (2nd [P/Y]). If these are set correctly, could you post the problem you're trying to solve, giving both your results and the expected results?
Oct 27, 2010 | Texas Instruments BA-II Plus Calculator
BAII Plus TVM Applications
2nd [CLR TVM] (clears any previous results)
4 I/Y (4% interest rate)
1 2 0 0 +/- ($1200 monthly payment, negative because you're paying out the amount)
2 5 0 0 0 FV (desired value, positive because you'll be receiving the amount)
CPT N (compute the number of payments)
Feb 14, 2010 | Texas Instruments BA-II Plus Calculator
Can you use the ti-83 plus as a finanical calculator. if so what are the keys for pv, pmt fv and interest
Click APPS and then ENTER for Finance and then ENTER again for the TVM Solver. There you can input the PV, PMT, i, etc.
Jun 22, 2009 | Texas Instruments TI-83 Plus Calculator
Calculating PV where n=5; i=6%; $18,400=pmt; 0=FV.
Check to make sure you have the proper value set for payments-per-year.
Mar 27, 2009 | Texas Instruments BA-II Plus Calculator
My BAII isnt calculating correctly
Change the payments-per-year to 1 to get the correct answer. Press 2nd [P/Y] 1 ENTER.
To pay off a loan of $3245 at 12% annual interest, you can either make 6 monthly payments of $559.91 and pay it off in half a year or make 6 annual payments of $789.27 and pay it off in six years.
Jan 15, 2009 | Texas Instruments BA-II Plus Calculator
Computing N in a TVM calculation (receive Error 5 message)
Hey,
Just found out the answer!
Apparently you can't have both FV and PV positive. Try the calculation with one of them being negative.
Jan 12, 2009 | Texas Instruments BA-II Plus Calculator
How to use my calculator
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=2&appId=6114
Feb 17, 2008 | Texas Instruments BA-II Plus Calculator
I do not have the directions and need to figure out how to calculate mortgages.
Here is the link to a guide;
http://www.buec.udel.edu/bowersh/finc311_F04/Documents_f04/Quick%20Guide.pdf
Set PV=-$100,000
[2nd] P/Y= 12.00
N= 12 x 30 = 360, (i assume it's 30 Y amortization)
I/Y = 5.75%
FV = 0
[CPT] PMT
Hope this helps
Jan 16, 2008 | Texas Instruments BA-II Plus Calculator
Texas Instruments BA-II Plus Calculator Logo
300 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
