Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
MAYTAG MAV7757AWW LEAVES CLOTHES DAMP - Maytag Ensignia 3.3 cu. ft. Top Load Washer
SOURCE:
SOURCE: maytag washer mav7757aww
I had the same problem with mine a couple of years ago and it ended up being the transmission was shot. Apparently this is a common problem with this washer. Google it and see.
Posted on Oct 21, 2008
  • 3741 Answers
SOURCE: wet clothes after spin cycle
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 05, 2009
  • 187 Answers
SOURCE: Our machine does not always spin the clothes completely "damp"
Hi,  try these:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate my suggestion....
Posted on May 22, 2009
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: spin cycle not drying enough
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My maytag bravos dryer is not drying?
sounds like your heating element is going bad
Jun 17, 2012 | Maytag Dryers
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
My Whirlpool dryer suddenly leaves clothes damp
Be sure to check the thermostats...they can cause this problem
Sep 22, 2009 | Whirlpool Dryers
Older maytag kd806 clothes damp when it shuts off
Check your vent and duct system. It may be clogged and the air will not flow out if this is true. How long has it been since you replaced your vent ducting begind the dryer? They don't make them like they used to so the longer you can keep this one, the better off you'll be. Hope this helps you! We have parts! Ella
Aug 18, 2009 | Dryers
Clothes only warm and damp after an hour
try checking to see if the vent is plugged up, this includes the lent catcher the hose and the outside ait vent.
Jun 26, 2009 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag washer mav7757aww
Oct 21, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag coin operated dryer
is the dryer heating at all? have u tried it disconnected from the vent to see if it makes any difference, if disconnected and it still doesnt work correctly u'll probably need a new thermostat it also depends on if it gas or electric heating elements in electric are either good or bad no in between its just a coil
Mar 04, 2007 | Maytag MDE16CS Electric Dryer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
