Important Note! Do Not use "One-Time Mode" sync. Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off. 1. Insert a Wii Balance Board compatible game disc in the Wii console.2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board. 5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking. 6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
The exact procedure is:
• Even if the battery level is strong, try the following:
Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
Try these steps!
Turn the Wii console power OFF by pressing the POWER Button on the
front of the console. Unplug the power cord from the wall outlet for a
few seconds. After a few seconds have elapsed, plug the cord back into
the wall outlet.
2 Turn the power of the Wii console ON. When
you see the Health and Safety screen, open the small flap on the front
of the Wii console to find a red button labeled "SYNC." Press and hold
the SYNC Button down for 15 seconds. This will clear all the syncs on
the Wii, allowing you to get a clean start to begin the process
described below.
3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
a
With the first Wii Remote you wish to sync, remove the battery cover on
the back of the Wii Remote to find a small red button just below the
batteries.
b Press and release the small red button just below
the batteries on the Wii Remote; the blue lights on the front of the
Wii Remote will blink.
c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
d
When the Player LED blinking stops and stays lit, the syncing is
complete. The LED that is illuminated indicates the player number (1
through 4).
4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
get a new board or get it fixed,
try different batteries
dont put any unessessary weight on it
dont stomp on it or jump
be gentle with it
get a new peice so no re-scyn
make sure its not too close too the wii
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
1. Start the game from the disc, and wait it to run.
2. Press the sync button on the wii fit balance board.
3. Press the sync button on the wii console.
Some people say that holding the wii console sync button for 7 seconds works best.
