Kenmore 24 in. 15079 Built-in Dishwasher Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After washing it appears white on all the vessels. It started happening recently. how to fix it?
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Nov 27, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232718
Points
12714
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Suddenly I had a really sharp pain shoot through my right eyeball then a broken blood vessel appeared please tell me why this could happen is it dangerous
Broken blood vessels in the white of the eye are not uncommon, but pain is a concern. Go see an optometrist first, as they have the right equipment to look at all of your eye. The opto may give you a referral to doctor.
1helpful
2answers
Water level in new toilet bowl to low
water level in the bowl( pan) is determined by the height of the sewerage pipe level that it is connected to and is fixed by design and style of the pan
unless you are on about the water level in the cistern( tank) which you can adjust yourself
I've a 97 bosch wff2000, washes, drains but will NOT spin either after main wash, rinse nor does it do the final spin. Had it from new, so definately can't complain. I've just replaced brushes...
Try disconnecting the small bore hose from the pressure chamber it could be the switch has stuck in the on position in which case the pressure chamber is blocked (the chamber is at the other end of the small bore hose )
1helpful
Have a ecotec 824 plus boiler the bar goes upto 2.7 and stays round 1.5 when not operating,what is causing this?
Sounds to me like the expansion vessel is not working correctly. When the boiler is on the water gets hot and expands into the expansion vessel but if the vessel is not working the pressure will rise and will eventually escape through the pressure relief valve.
1helpful
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
2helpful
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
2answers
Machine not starting at all.
the white box you refer to contains the main module which drives the whole issue. with no start, this module is probably faulty and is an expensive part
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
