It is likely that the print-head temperature sensor is detecting an over heat. If that is the case, start thinking about a replacement machine as the printheads are expensive to replace.
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Remove the print head and cartridges.Unplug machine for 30 min.
Repower and reseat head and ink do a head alignment.
If this does not correct it may require service.
Ink Cartridges are the BCI6 and 3 series correct?
If using CLI8's and they are flashing red you have a bad cartridge or it is in the wrong location.If so Canon will replace the bad cartridge.
I had the same problem. The Canon web site recommends resetting the print heads, but this didn't work for me. Here's a link to their recommended solutions:
I have two Pixma 780's. After getting the "wrong cartridge" error one day when I turned it on, (I knew it was the right cartridge) I tried switching ink tanks, and the print head cartridge several times between the two printers. the problem followed the black print head cartridge, so I am guessing I need a new one. From that experience, I would recomend swithing the print cartridge if you get this error. Does anyone know how to do a reset on this machine? A Canon tech told me once, but I lost the info.
