The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
If your evaporator fan is working properly the water would evaporate back into your home or business. If the evaporator fan was not working the freezer would not freeze and fresh food would spoil. That is way too much normal condensate unless there is a leak around the door seal or leak in the cool water supply tank storage or filter area. Not knowing the model number I would think you may have a drain opening under the crisper drawer that leads to pan. And think it may be a good idea to turn water supply off until sure of the source. Click here=> Leaking Refrigerators Just What may Be Happeningand Click Here=> Leaking Refrigerator's?Locate model number for Kenmore Here=> Kenmore Model Number Locator's Most other model number locators are about the same as on the left sidebar on the Leaking Refrigerators page. I will be here to answer further questions, and there are a lot of things to look for on that page, Thanks, Sea BreezeClick on Logo enter your model for parts breakdown=>
Clean the drain pan and drain line in the back of the freezer section
underneath the evaporator coil. Make sure water drains when you
pour it in. If it doesn't - also clean drain tube on the back of the
unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
you are right about the cause of water in the fridge - blockage in the drain. i'v never met this caused by ice but it is possible.
with the freezer, the cause of the fault is the fan not working - probably jammed with ice. take back panel off inside freezer and check for ice build up. if loads of ice thgen defrost system has failed. you can do a temporary repair by melting the ice off with a hairdryer
you said, For the past three days, water has been leaking/freezing at an alarming
rate. The freezer had about 2 inches of ice built up and the bottom of
the refrigerator is holding water, too. Both crisper s were FULL of
water. I don't know if the ice maker connection is broken or what. Looks
like I have to cut off the cold water completely to the sink to get it
to stop.
Sounds like the ice maker or its line is leaking the water to me. And obviously it will freeze in the freezer.
You need hands on service. Our site provides service companies in your area. bless you, Please give me a good rating before you sign off Thank You
