SOURCE: gigaset se568 siemens wireless Security
To reset this router, there is a reset button at the back of the unit, use any metal or pin with the small tip push the button for at least 10 seconds while the router power on, pull the pin and check the router if all LED lights on, you will successfully reset your router.
If your router keep resetting, this is due to unstable dsl signal, contact your service provider to check this problem, maybe there is a problem with the port termination.
About security setting, you can set security key at any options by entering 10 digits number, goto network options and click wireless setup wizard, enter the SSID or router name, click next unit security option appear and select enable then input shared number at least 10 digits and click finish.
SOURCE: how do I open a port using a Siemens Gigaset 204A
you cant open a port on this modem because there is no firewall integrated check your router
or your windows firewall config
plz rate
SOURCE: My Siemens Gigaset 204A modem is not synchronizing
Please try to install your Siemens modem's driver 1st on your PC but must be sure that driver will be Vista supported.
