Master
- Posted on Nov 27, 2010
Re: Do you know how to reset the Attention light on a HP...
Try below resets
Power Drain:
- Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
- Press and hold the Power button for 60 seconds.
- Connect the cable and turn ON the printer.
Partial Reset
- Remove the power cable from back side of the printer while its ON.
- Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
- If printer turns OFF, press power button to turn it ON.
Semi-Full reset
- Remove the ink cartridges.
- Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
- Insert the ink cartridges.
NVM Reset
- Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
