SOURCE: Downloading video from Panasonic NV DS60 using windows movie maker
have you tried going to Panasonic site and searching for a download Vista patch?
SOURCE: PLEASE HELP ME! Panasonic firewire connection won't work!
u need to call panasonic 4 the softwarw...there is a software the sell 4 the firewire issue....
SOURCE: PV-GS120 video transfer problems
Ilink 1394 works fine with SP2. You should have got a driver CD with the 1394 card. Suggest you reinstall the drivers.
pliss send my draiver camera
SOURCE: Can't get video or pictures from Panasonic PV GS9 to computer
ok i hope you have a windows computer or at least you somehow got windows movie maker on a mac. go to capture video in windows movie maker and then capture it!
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
