I am charging the battery on my new laptop e528 series. The green light is on but these is a red light that appears and then goes off. The quick start manuel states that a blue light will come on when the battery is fully charges, but I cannot see where it is on the front left where the green and red lights are. How long to fully charge the battery.
Thx
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery.
This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
