The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Just fixed the E:27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal. this should be in the manual. shame on bosch.
HI THAT MEANS door is locked and will not start PLZ VISIT THIS LINK
http://laundry.manualsonline.com/support/bosch/washer/error-code-e27-3495138
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
