Right click on the program, then click properties and compatibility.
Choose Windows XP. If you still get the error, try a different option instead of XP.
install it using compatibility mode. right click on the setup file, go to compatibility tab and select compatibility for a different type of windows. try using windows xp as a compatibility. install it and make the same thing to the .exe file
You may need to change the setting on the games desktop shortcut. "Right click" on the game icon, click on properties. Then click on the "compatibility" tab. Check the "Run this program in compatibility mode for" box then click the down arow and select "Win XP SP2 " Click appy then ok. The game should run.
It's condensation if you haven't got a leek if you leave the tank full of fuel this should not happen we had this problem for years with combine harvesters and leaving them full and not empty cured the problem
The game John Deere American Farmer is designed to be used with Windows ME, 2000 or XP, therefore in order to use it in Vista you must run your game using Compatinity Mode --> Install your game--> Go to your Desktop --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
I hope this helps
Please take a moment to accept and rate my solution accordingly
