NO PC stated, just compaq,, 1984 compaq,? first one.
must we guess what you have?
NO OS stated, we guess that too? wow.
windows ? if yes, what windows, we cant guess that ever. (even linux uses and OS/2 on some)
no statement of what you are doing? PC do lots of things. endless.
my guess Ethernet cable fails>? using CAT5/6 cable?
if the modem is dead on 2 PC, wired
call the ISP it is their issue.
if the 1 pc ONLY fails on that modem
then that PC drivers are bad. if wired
if wifi 20 more things, complex it is ,ask if doing that.
SOURCE: driver for pctelplatinum v.90 modem
Hi Does this modem use a 62802-51 controller chip ???
Charles
SOURCE: 4100 Modem telling me to install ethernet adapter
You do not state if the ethernet had been working before. If this is the first time to use the port on the computer, it often needs to be turned on in the BIOS of the mother board.
SOURCE: How to install zte 831 aii Broadband modem in Linux with USB
I was working at one of Lithuanian internet service providers. We often had clients complaining about ZTE 831 connecting through USB. The answer is - use a LAN card. Sorry.
SOURCE: non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
SOURCE: When connecting to the internet via Dialup I get Error 633
Shut down the computer for arround 10 minutes and then restart it after that you can try to connect
