SOURCE: I can't get our Samsung Blu-ray player(Model
I am not an expert a "tinkerer"at best but I do have the 3600 like you and I have no problems connecting. Make sure there aren't any spaces or special characters in you router name. Follow your instruction manual and get the 3600 connected first then try netflix: Menu, setup, network, set your settings and it will tell you available networks, choose yours, enter your security code then do a connection test. If its not connecting at what step are you having a problem?
SOURCE: Movie 2012 BluRay loads menu but won't play on
Sony releases new firmware for the bdp-s350 ever so often to let it play newer movies. The last one can be downloaded from here firmware. Be sure to contact Sony with any problems so they can work on it for the next firmware. They are pretty good about updates as long as we let them know of any problems we are having.
If you are continuing to have problems let me know by sending me a message in the comments and I will go from there. I will get back to you as soon as possible.
Take it easy and hope I helped.
SOURCE: Is there a hack to allow netflix to stream on a
Unfortunately, the Blu-ray player does not have the hardware acceleration to playback videos from Netflix. Hence it is not possible to playback Netflix in this..
