Microsoft Office 2008 for Mac: Mac Logo
Posted on Nov 25, 2010
I tried moving my word application to my desktop and now when I go to open it a error comes up that says that there was a problem opening word and it tells me to reinstall the program. I put in my office cd to download it but it says it is already installed and wont let me do it?
Charvin Bajet
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Feb 17, 2011
Charvin Bajet
Contributor
Level 1:
New Friend:
Answers
51
Questions
Helped
13877
Points
77
That's actually a normal problem. You don't need to reinstall Office Mac 2008. What you need to do is to put the the Microsoft Word icon from your Desktop back to Applications Folder. To create a shortcut on your Desktop, go to Applications folder, Right Click(Ctrl+Click) on Microsoft Word then choose Make Alias. Just drag the Microsoft Word Alias to your Desktop. From Desktop you will have Word as a shorcut icon without any problem. If the issue will not be resolved then you need to uninstall then reinstall Office. Here's the steps:
] > Macintosh HD\Applications
* Remove Microsoft Office 2008
] > Macintosh HD\Users\<username>\Library\Application Support\Microsoft
* remove folder called Microsoft
] > Macintosh HD\Users\<username>\Library\Caches
* remove all Microsoft related files
* remove Microsoft Folder
] > Macintosh HD\Users\<username>\Library\Preferences
* remove all the (com.microsoft.[....].plist files)
* remove Microsoft folder
] > Macintosh HD\Library\Receipts\Remove all Office 2008.pkg files
] > Delete Microsoft Office shortcuts from Dock
] > Restart
] > Install Office 2008
> Manual Install Updates
I hope this Helps! :)
I installed photoshop 7.0 on my pc.when i tried to start it the error comes "could complete your request because of missing or invalid personalisation"
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Cannot open the application,move it from the Trash.
This error message only appears when you are trying to run an application that is currently located in the trash. Try dragging the application out of the trash and onto the desktop, then open it.
Tray on tower won't come out
Dear sir
i try open google chrome but get massage window application error the application was unable to start corroctly(0*c00000a5) click ok to close the application
thank you
I always get 2 error messages when I open my MS Word program: 1. Please wait while Windows configures Norton Antivirus 2005. The other one is: 2. Norton Antivirus 2005 does not support the Repair feature,...
Try uninstall norton antivirus and load avira antivirus, run word program and check whether an error will come out. If no error, your antivirus might be corrupted and somehow affects your application. If error still occurs after replacing norton, uninstall office program and reinstall again.
1helpful
I receive the message "An attempt was made to move the file pointer before the beginning of the file." What does this mean, and how can I open this file?
in case you have started to receive this error while trying to access a particular application, please try to reinstall the application.
In case that the number of applications that are giving the error message is more.
Try a system restore to a date when these errors were not coming up.
Once you do a system restore please also try disk defragmentation.
I think this should work for you.
Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, y
ou should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
2helpful
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
2helpful
2answers
On Mac, not receiving e-mail--everything else works
Hi knittique Sorry to hear you are having problems,
Are you getting any error messages when you check mail ?
I would certainly call your eMail hosting company, don't wait for them to call you back...
Sometimes, a mailbox can get corrupted.
One test you can do is to use this service:
http://www.mail2web.com/
you can see if your mailbox is still active and working.
1helpful
3answers
Desktop screen is not coming
this is possibly a virus infection where you will not see any icons on desktop and mouse clicks do not responds.in this stage you can run the required applications from the task manager...just press Ctrl+Alt+Delete and click on NewTask and type the applications to open (write "explorer" without quote to open MyDocuments)
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
