Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a maytag fav6800aww and it doesnt want to drain the water and it makes a loud noise coming from the pump. i already replaced the pump and it still has the same symptoms. what should i do to fix this problem.
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Nov 25, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10844370
Points
101584
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Maytag insignia- noisy spin and doesn't pump water out
If your Maytag washing machine is making a loud noise during the spin cycle and is not draining the water, there are a few possible causes. Here are some steps you can take to troubleshoot the problem:
  1. Check the drain hose: Make sure the drain hose is not clogged or kinked. If the hose is clogged or kinked, water may not be able to drain properly.
  2. Check the pump: The pump is responsible for draining the water from the washing machine. If the pump is not working properly, it may be making a loud noise and not draining the water. You can check the pump by removing the front panel of the washing machine and locating the pump. Check for any visible damage or obstructions.
  3. Check the belt: The belt is responsible for turning the pump. If the belt is worn or broken, the pump may not be able to drain the water properly. You can check the belt by removing the back panel of the washing machine and inspecting the belt.
  4. Check the bearings: The bearings are located in the drum of the washing machine and can wear out over time, causing a loud noise during the spin cycle. If the bearings are worn out, they will need to be replaced.
If you are not comfortable troubleshooting the problem yourself, you may want to contact a professional appliance repair service for
1helpful
My Maytag Neptune washer -FAV6800AWW make very loud noises during the spin cycle.
if its a rumbling noise its the bearings which need replacing which is a major job
Maytag MAV7550AWW makes very loud noise while draining, although it still drains and spins out.
Check the pump. Maybe a coin or something got in the impellers. Another is to check the belt and pulley along with the mounting of the pump.
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
2helpful
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
1helpful
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Loud noise at end of Draining
If your dishwasher seems noisy, check these:
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
good luck
thanks for using FixYa
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
