SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
SOURCE: stop button, fan button, up incline button are not
If some buttons work, you more than likely have a key pad problem. Unfortunately Icon doesnt sell kep pad seperately. As a last effort, try heating up those buttons wit a blow dryer. This will work temp. sometimes.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I have a NordicTrack A2250, about 2 years old.
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
